820-00165 pulsing twice
Narek
I'm working on 820-00165 board, which came to me completely dead. After inspection I found out:
- small corrosion between C7400 /C7425 and C2951/C2952
- PP3V3_S4 was completely shorted to ground, but it was caused by damaged U8000 (no corrosion around).
I've replaced caps and U8000. Now board is pulsing twice without fan spin and nothing other happens. All S0 rails are pulsing, including CPU and PCH VCORE.
What I have done so far:
- checked U6100/J6100 and all termination resistors
- tried new SPI chip and known good BIOS with clean ME region
- replaced U6101 and U1900, area of U1950 looks perfect
- there are no broken/corroded traces or test points
- checked current sensing resistors, even replaced U7100
- reballed and then repalced SMC (just in case)
- SMC bypass gives me two short fan spins, then nothing. After pressing power button i get only one fan spin.
Is it worth spending time and digging into this board or it's obvious behaviour for damaged of CPU/PCH?
There could be accumulated crap underneath CPU; especially PCH area.
You can try to heat it, just in case.
PLT_RESET_L pulsing too?
