820-00165 Slow SSD
CRC2018
So i've got an 820-00165 board in at present - was water damaged and repaired backlight circuitry in the past but it's been returned with an issue of running very slow.
The system works perfectly when I use an external USB hard drive loaded with Catalina - no slowdowns or freezes at all fans run normally etc. The issue comes when running off the internal SSD - I initially thought it was an issue with the customers install so have reinstalled it with a fresh copy of Catalina but still the performance issues persist. It runs slowly - freezing, beachball appearing just generally a very laggy experience.
Now given I do not presently have another SSD which is working and compatible with this system I cannot currently try that - I have ordered one to see if this is a simple case of a dodgy SSD which i'm thinking is probably the most likely issue but I would like to ask everyone here if there's anything on the board I might want to check which would cause only the internal SSD to run badly but wouldn't affect the external drive?
This should be SSD issue.
All data lines should be good, if you can still run macOS on it.
Don't waste time on it before getting known good SSD for test.
