820-00165 won't turn on if IO cable is connected.
Aivaras
Had liquid damage around smc and few shorted PPBUS_S5_HS_COMUTING_ISNS CAPS.
After cleaning liquid damage and replacing caps now only turn ons if IO cable isn't connected/.
If IO cable connected orange light is there.
Inspect LIO connector.
Try known good LIO board/connector.
Check for short or low resistance on all power rails which go to J9500; when it is connected.
JohnB8812
Sounds like you're not using an OEM 85 Watt Magsafe 2 adapter. Definitely also measure what 2informaticos was asking
Aivaras
Thank you guys. Works as it should it genuine charger. Can someone explain why it won't turn on with power supply(cable is from genuine 85w charger)
JohnB8812
Yes using the adapter OR using an NON OEM charger causes lots of issues with 2015 machines for some reason. Always need OEM chargers for these no matter what
Handshake protocol on the latest Magsafe 2 machines is a bit different than the old one.
And Magsafe 1 cannot comply...
