820-00165 wont turn on with battery
820-00165 Water damaged around U5000 and U5110 did not turn on
Reflowed and cleaned both areas and macbook turn on with adapter but wont turn on with battery
With known good battery and adapter:
-Screen shows low battery image, turn off and a sec and shows low battery image (loop)
-PM_BATLOW_L 3.4V
Any suggestion?
Thanks a lot
ALWAYS reball SMC when you found corrosion on its area.
Does the machine stay on with battery alone, if charger is removed?
Inspect J6950 for corrosion; be sure its pins are not half broken.
