820-00165A no charging light (amber or green)
ppvout.s0
I am fairly new at this but i've the following MacBook Air A1466
PPBUS_G3H it present but a little low and i think the SMC stays in reset mode.
I've measured the following power rails:
PPBUS_G3H = 8.20 volts
PP3V42_G3H = 3.416 volts
SMC_RESET_L = 0.754 volts
U5110 voltages:
pin 1 = 3.415
pin 2 = 0.000
pin 3 = 3.414
pin 4 = 2.815
pin 5 = 0.784
pin 6 = 3.399
pin 7 = 3.409
pin 8 = 3.294
I thinking SMC_RESET_L is too low whats causing the SMC to keep resetting? What should i do next?
Diode mode to ground?
Check R5100.
Clean/remove J6100.
Remove R7100 and check voltage again.
If still low, remove U5110 and retest.
SMC is the last option...
ppvout.s0
Thanks,
checked R5100 which had abnormal values.
Checked J6100, saw a little debris. Cleaned it and the MacBook works again. Thanks!
