820-00239 does not accept commands
iClub
presents the folder with interrogation, I have already tested the external keyboard, disconnected the flats and used a Bios file ok, but without result.
Cannot access boot menu?
Did you try to boot USB macOS?
Is J9600 installed?
iClub
It is connected j9600.
The boot menu does not appear and when holding CMD + R it does not appear either. It is only on the INTERROGGATION PASTER.
iClub
same thing stays only in the INTERROGATION PASTE.I tested it with another keyboard and apartment. I disconnected the peripherals, but I didn't have a different result.
iClub
yes I did. the following message appears “the software needs to be restored, as there is a critical system error”. Trackpad and wifi don't work on this screen.
Did you try all steps recommended for critical error on touchbar machine???
iClub
PP3V3_2V7_NAND_VCC 0v.
PP1V8_SSD_COLD 0V
STORAGE_LB_EN 0.42V
SSD_RESET_LB_L 0.42V
LPSR_EN_LB_L 1.34V
SSD_PCIE_CLKREQ_LB_L 1.34V
SSD_BOOT_LB_L 0.81V
R9406 2.2ohms
iClub
There is no SSD/NAND short in reference to the ground.
Still cannot access USB boot?'' I cannot enter the boot menu.
I identified that R9350 has 200k instead of 1.3M, replace with an equivalent, but I didn't get a result.
iClub
STORAGE_LB_EN 1.55V
SSD_RESET_LB_L 1.73V
PD_L 0.75V
SSD_PCIE_CLKREQ_LB_L 1.75V
"Be sure J9600 has good contacts" are all good.
"3V3_S5_SSD 766mV"
Do you also miss PP3V3_S5_SSD_LB?
If yes, bad contact on J9600.
Be sure no short at PP3V3_S5_SSD_LB and then you can bypass J9600 with an wire.
