820-00239 no voltage on l7410/20/30
TBFix
There was initially 1v on ppbus_g3h swapped out u7000 and getting s0 voltages except no voltage to l7410/20/30.
I have
PPVCC_S0_CPU 1.07v
PPVCCSA_S0_CPU 1.94v
PPVCCGT_S0_CPU 0v
ALL_SYS_PWRGD
PM_PCH_PWROK
PM_PCH_SYS_PWROK
PLT_RST_L
all 3.3v.
Tried god bios, still same
What else to check ?
iGPU core voltage will not appear until high graphics load is detected; is the normal behavior.
CPU core should drop from 1.07V to aprox 0.6V, after 5-10s; when the board really boots.
Any history available?
TBFix
Some small sign of spillage on the board .After changing u7000 board then began to power up. Currently draws .500ma 20v. no display. Cpu gets warm.
Something else affected by liquid spill.
Do you get PLT_RESET_L?
Check all SPI Bus Series Termination resistors and traces.
TBFix
Hi yes I have PLT_RST_L all termination resistors/tracks look ok. No other obvious spillage. Any other signals to look for that would explain the 500ma 20v and no display?.
