820-00244-A no PPBUS_G3H
BlueGold
Hey Rossmann Team,
I have a Problem with 820-00244-A Logicboard.
I dindt have any sign of life. no current on USB-Ports.
So i decided to change the U3100.
Now i have a low current. (0.025A) for few seconds and then 0,0.
Cause the missing PPBUS_G3H i changed U7000
but it doesnt make any difference.
P_IN: 5,19V
SMC_RST_IN: 0 V
VDDA/P: 5 V
SMC_RST: 0.6 V
A/BMON: 0V
Thanks
BlueGold
The USB Flex is new, the old was brocken.
Sadly no.
A B2B customer sended it. I dont like when other guys worked on the Mainboard but the data is important.
Input voltage can't switch to 20V without 3V3_G3H.
SMC must talk with CD3215 chip and this voltage is required.
Post its diode mode to ground reading.
Yeah, but I prefer to get the readings on the interesting lines; instead of looking of that screenshot.
Like the LDOs lines of U3100, for example.
You've posted some signals and voltage for U7000, but we need more; ACIN, VR_AON, ACOK, LDO_3/5P0.
If any missing, check it in diode mode too.
BlueGold
i have 1.23 V now. Maybe i measured wrong, cause C7022 has 5.19V. Whatever. Is there a list for what Voltages are important and what voltage i need ?
Having 3V there doesn't assure all is good.
Lower diode mode reading than expected, may be caused by a bad component in that line.
BlueGold
okee the problem is i dont have good board to compare. What is the right value?
What about my missing 3V3 ? will a bad component in tzhat line cause this too ?
BlueGold
I thinked of that and replaced U7000.
I will make it tomorrow.
Sadly my customer will wait only until tomorrow i hope it will work.
