820-00244 no power
Kyle93
Arrived with no power. Client claimed liquid damage but no corrosion was found on the board. Discovered Diode mode reading lower then a good board on PPBUS_LIO. When U3100 is replaced, diode mode reading is normal again however once power is applied the same lower reading occurs. Board uses 5v 0amps.
Also tried to replace U7000 but no change
pp3v3_g3h 0v
Trying to fix for data recovery
That is no short and value looks good for CD3215 chip.
Check diode mode to ground at PPBUS_G3H, 3V3_G3H and other coils.
Remove F7040 and check C7043 voltage.
Kyle93
p_in 5.18v
SMC_RST* 0.485v
SMC_RST_IN 0v
VR_AON 2.995v
VDDA 4.73v
VDDP 4.95V
LDO_3P0 2.995V
LDO__5P0 4.95V
AC_OK, 0V
A/BMON 0V/0V
