820-00244 no water damage, 0V on the charger
MaxFix
1. 0V on the charger
2. replaced U3100, now 5V on the charger. U3100 replaced with the same model B01 but from another donor board that had 20V on charger.
3. All big coils 0V. PPBUS_G3H - 0V. P3V3G3H - 0V.
4. Checked for short on all the big coils. L7210, L7230, L7410, L7430 seem to be shorted. shows 16 in diode mode and gives a constant beep.
Please advice how to proceed.
CPU coils could have low values anormal.
Someone else can confirm if has similar board.
Do you get 3V0_AON and PP2V9_SYSCLK?
Post basic voltages for U7000.
Check P_IN, ACIN, ACOK, A/BMON, VDDA, VDDP_1/2, VCC_VR1.
Use surrounding components to measure, if no test points available.
MaxFix
P_IN - 0V
ACIN - 0V
ACOK - 0.07V
CHGR_BMON - 0V
CHGR_AMON - 0V
CHGR_LDO_VDDA - 4.98V
CHGR_LDO_VDDP - 4.98V
VCC_VR1 can not find this value
MaxFix
CHGR_LDO_P5V0 is confirmed.
P_in witch one? I don't find just that line. are those capacitor near the CPU?
MaxFix
U7000 lines
CHGR_ACIN - 1.08V
SMC_BC_ACOK - 0V
CHGR_AMOR - 0V
CHGR_BMOR - 0V
CHGR_LDO_VDDA - 4.8V
CHGR_LDO_VDDP - 2.62V
It is probably waste of time; all A1534s end with dead CPU anyway.
You can only try if find ISL95530 from same model board.
