820-00281-10 not drawing 5v instead of 20v
Soji
The system came fresh and pp3v3_g3h voltage is low 2.6v instead of 3.34v
No PPBUS_ G3H
I found a low resistance on c7081, I ran a current throug it. Same c7081 gets hot. I replaced it and the resistance came up. But still 5v. I proceeded to replace u6903 and D6902. It draws 20v and immediately retuns to 5v.
The reading now or
Amp meter drawing 5v/ 0.04amp
PP3v3_G3H- 0.360/ 0.00v
PPVIN_G3H_P3V3G3H-0.183/1.6v
PPDCIN_G3H_CHGR_R-0.555/5v
Pls help
Soji
After I have removed C6905/06
PP3v3_G3H- 2.23v/ 0.363
PPVIN_G3H_P3V3G3H-4.0/0.551
Still no 20v
So your problem is on 3V3_G3H power rail now.
You can inject 3.5-4V and look at MLB with IR camera.
Remove heatsink first...
Soji
U5000 gets little warm. I replaced it. And I removed r6923 to check the voltages I get on the resisto
Pin1 3.4v
Pin2 0.00v
I now decided to put it back
PP3V3_G3H - 2.2v
