Post U7000 basic voltages; P_IN, AUX_DET, VDDA/P, EN_VR1, SMC_RST*, AUX_OK, A/BMON.
Check diode mode to ground at PPBUS_G3H and all big coils.
SMC_USBC_INT_L goes high?
Test with known good battery (charged).
Also be sure to use 87W charger.
P_IN = 5.1 Volt
AUX_DET = 1.2 Volt
VDDA = 5Volt
VDDAp = 5 Volt
EN_VR1 (R6921) = 5 Volt
SMC_RST = 3.4 Volt
AUX_OK (Q5490 pin2) = 3.4 Volt
(D4)AMON CHGR_AMON = 3.4 Volt
BMON CHGR_BMON = No Voltage
I checked again this morning and saw 20 volts instead of 5 volts on the keweısı. But the amperage drawn is 0 when I first plug it in, it draws 0.17a and then it drops to zero.
No original charger. I tried it with its own battery, it didn't charge. The charger I am using now creates all voltages on the same model motherboard.
