820-00281-A No power
twitchedonjay
Hey I have a 820-00281 Motherboard with no power. No water damage but inside was really dusty. I got the following readings
ppbus_g3h = 12.61v
PP3v3_G3H = 3.4v
PP3v3_SUS = missing
PM_BATLOW_L = missing
PP3V0_G3H= 3.0v
PCH_INTRUDER_L= 2.8v
PM_DSW_PWRGD = missing
PM_SLP_SUS_L= missing
RTC_RESET_L= 3.0v
PCH_SRTCRST_L= 3.0v
3V3_S5 = missing
Can you please help me troubleshoot this unit?
twitchedonjay
Okay i tried with the hz setting on my multimeter and got 32.76khz on sysclk_clk32k_pch (u1900 pin 10)
JohnB8812
Yeah which makes me think the SMC is possibly pulling it down similar to older machines. Inspect near U7000 for corrosion as well. I think one or the other could be keeping PPBUS low which explains why many of the voltages you are missing are missing
twitchedonjay
So would the crud around U7100 cause anything. its EXTREMELY minor and can only be seen under the scope but there. I went ahead and did a beep test to check short to ground. I have beep on:
CPU_VCCGTSENSE_P
CPUCORE_ISUMN
CPU_VCCSENSE_N
Are these suppose to beep due to low resistance or are these lines shorted?
I don't exactly know the corresponding values for your CPU.
But yes, CPU rails have usually very low values...
