820-00281 boot issues
No-Clean
Board was messed with before it came to us, Mac had the typical flexgate issue, we fixed that and realized that the other place had shorted the LCD connector and it gave no image any longer after that, after replacing U9850 I got image again, but now the problem I am having is that the OS wont load all the way or worse if I boot holding ALT bot the boot loader the Mac freezes right away, sometimes even without holding ALT the Mac just shows a blank screen.
Already tried clean BIOS found here on forum, but no luck.
I cannot even try to boot from external system since the Mac freezes before even selecting the alternate disk.
No-Clean
I don't have Windows or Linux, but when booting in safe mode there is a variation, the folder icon flashes when booting in safe mode, I tried removing J9600 and botting in safe mode, same thing happens, flashing folder icon.
No-Clean
This was done also for external drive, Mac starts to boot but it reboots when the bar barely starts to load.
No-Clean
No-Clean
Yes, external USB drive with macOS connected and J9600 disconnected Mac starts to boot but it reboots when the bar barely starts to load
I still recommend to test with Linux, or Windows.
GPU driver is not loaded in such case; will help to diagnose such issue.
No-Clean
Tested with Linux and J9600 removed, some text starts to scroll on screen but shortly after it reboots and starts over again, Linux OS never loads, I also tested that Linux install on a different Mac and it works.
Reconnect J9600 and start in Target Disk mode; save any data, if needed.
Then start Internet Recovery and check if is possible to reinstall macOS.
No-Clean
When starting in target disk mode as soon as the icon comes on screen the Mac freezes, same thing when trying to install the OS over internet, I am done with this Mac, thanks for help.
