820-00281 no power. Liquid damage.
BCN_Techs
Got 820-00281 with liquid damage on UA900 area.
Replaced:
UA900
CA902
CA903
CA901
CA900
CA905
RA900
They were fucked.
Now getting 20V from the port but the machine doesnt start.
Measurements:
PPBUS_G3H 0V (shorted to ground. Injecting 5V nothing warming)
PP5V_S5 0.33V
PP3V3_S5 0.4V going down.
PP3V3_G3H 3.3V
PP3V0_G3H 0.4V and going down
Any suggestion?
Never inject voltage before checking if NO high-side MOSFET is shorted...
Which is the exact value at PPBUS_G3H 0V, in respect with ground?
Post it in diode mode, red probe to ground.
If is very low, then check exact value on 200 ohms scale.
"PP5V_S5 0.33V
PP3V3_S5 0.4V going down."
These require PPBUS_G3H presence first.
PP3V0_G3H is generated by U7800.
BCN_Techs
"PP5V_S5 0.33V
In Diode mode is very low: 0.002
Resistance to ground 1,2 Ohms
JohnB8812
Yep make sure charger unplugged. Remove F7000/1, and see if your short is on pin 1 or pin 2. If pin 1, inject 5 volts and see what heats up. If pin 2, start low around 1 volt and see what heats up. In a liquid damage case, I would not be surprised if pin 2 would be shorted through the CPU/high side mosfet as 2informaticos mentioned.
BCN_Techs
Shorted on pin 2 , PPBUS_G3H.
The liquid damaged very small area, UA900 and few componentes near it.
If the reading on PPBUS_G3H is lower than any coil, then is no shorted high-side MOSFET.
Should be a capacitor, or some IC directly connected to the main power rail.
However is no reason for GPU to overheat when inject, if high-side MOSFET of its power supply is not shorted.
Be sure you took correct readings from all coils...
BTW, don't quote an entire post; just select the related words.
JohnB8812
If the GPU is getting warm, that's not good. Inspect closely by it for caps that may be heating. If the only thing getting warm is the GPU, this is done
