820-00281 - No PPBUS 5V
menatwork
MB with no water damage, just stop work.
Here is some measurements and i hope you guys can give me some direction.
No short to ground on PPBUS_G3H
Diode Mode (red prob to ground)
------- U3200 Powerline
C3200 = 0.376
C3201 = 0.147
C3204 = 0.527
C3205 = 0.497
C3206 = 0.536
C3208 = 0.526
------- U3100 PowerLine
C3100 = 0.376
C3101 = 0.156
C3104 = 0.527
C3105 = 0.498
C3106 = 0.534
C3108 = 0.518
------- UB300 PowerLine
CB300 = 0.376
CB301 = 0.157
CB304 = 0.527
CB305 = 0.071
CB306 = 0.536
CB308 = 0.493
------- CB400 Power Line
CB400 = 0.376
CB401 = 0.156
CB404 = 0.527
CB405 = 0.498
CB406 = 0.536
CB408 = 0.521
J3300
5.20V (Power Meter) On and OFF
JB500
5.20V (Power Meter) Static
PPBUS_G3H = 0
PP3V3_G3H = 3.4V goes to 3.3V after a two second and stay in loop
Thank you
menatwork
I replaced UB300 and i got 0.453
However, still doing the same thing:
J3300
JB500
PPBUS_G3H = 0
Did you solder exact same chip code?
You probably have another bad CD3215, or maybe bad solders on the changed one.
menatwork
Yes.
What about the U3200 and U3100? Do you think the problem is just one ?
What else can i look to make sure that is the real problem?
You must be sure all chips are good and properly soldered.
If the problem is on the main power suplly, or some secondary supply, then all USB-C ports should have the same behaviour.
If you get one port with different symptom, that should point to an issue on the USB-C circuitry.
