820-00281 question, short on c3105
I have a 820-00281 that had no 20v, only 5v from the charger and that was cycling.
No pp3v3_g3h but no short on that line.
Found short to ground on c3105
Removed u3100, now short on 3105 is gone and pp3v3_g3h is normal but still no 20v on any of the ports.
I am not familiar with how this board behaves and I do not have another donor board to check with.
Will any of the other ports get 20v with u3100 removed?
I have several u3100 on the way.
Please write new post instead of comment.
No way to reprogram these chips.
You must use the same code; CD3215B03 will not work in place of CD3215C00, for example (nor viceversa).
