820-00840 5v on both port
Yoel Ren
Hi, this machine came in dead, with 5v on both port, consuming about 30-40ma
pp3v3_g3h is fine
ppbus not shorted
smc_reset_l 3.4v
buf_smc_reset_l 3.4v
Both of the cd3215 missing pp1v1 ldo, cd3215 has been replaced with KNOWN GOOD chip, still the same.
any pointer ?
Yoel Ren
clean board, customer as usual just say nothing happen it just dead some day..
smc_rst_in 0v
smc_usbc_int_l 3.3v
have tried removing the redriver chip too, but still same problem
Machine can work without U2800.
But will loss USB activity once macOS is loaded.
Post U7000 basic voltages; P_IN, AUX_DET, VDDA/P, AUX_OK, A/BMON.
"ppbus not shorted"
Can we give real diode mode readings?
Check in both directions, please.
Remove F7000 and check C7050 voltage.
Yoel Ren
found d3402 blown. but the line is not shorted.
found usbc_xb_d2r_p shorted, from u2800.
pulled u2800, and mac boot with 20v,
just need to pull another chip and install it to the mac, thank you so muchh for the pointer
