device turns into question mark after a certain time . I installed a different m2 SSD and reinstalled macos. After a certain time, the question mark appeared again. I wired L8600 to try, the result did not change
I noticed that the problem of detecting the disk does not occur when the charger is connected. But now it won't turn on when the battery is plugged in. After the device is turned on, I plug the battery flex, sometimes it draws 0.60 and sometimes 1.98 Amps. It says Battery is not charging. I ordered a new battery and will try it when it arrives. If the battery is faulty, can it cause the problem of not seeing the ssd? How can I be sure until the battery arrives? Is the problem in the battery or the motherboard?
Note: The original charger is broken. It charges once, then it doesn't, it's in a continuous loop.
SCL: 0.429
SDA: 0.429
R6950: 9.92K
pin 4 : 0.012 Voltage
pin5 : No voltage
pin6: 1.78 Voltage
pin7: 3.2 Voltage
pin8: No Voltage
pin9: 3.4 Voltage
pin10: 3.2 Voltage
pin11: 3.3 Voltage
pin12: 3.2 Voltage
Pin 13 : 3.2 Voltage
R8621 pin 1: 3.3v pin 2 : 3.2v
when not working
pin4 :0.009 Voltage
pin5 : No voltage
pin6: 1.77 Voltage
pin7: 3.2 Voltage
pin8: No Voltage
pin9: 3.4 Voltage
pin10: 3.2 Voltage
pin11:
pin12:
