820-00840-A no power, mac heats up and sometimes coller turns
iClub
helo, my friend I'm with this mac that has been in contact with liquid, the machine seems to turn on, but it doesn't show an image. the components D330 and D3300 are missing and it is slightly cracked. The region around U8400 suffered from oxidation, where I had to make a jumper in the ISNS_LCDBKLT_P U8400/c5452 mesh.
Voltage: PPbus_g3h 13.09V; PP3V3_G3H 3.42V; PP5V_S0 5.13v.
iClub
I noticed that the ISNS_LCDBKLT_P track didn't have a pad connection to the board, so I performed a jumper from IC U8400 to C5452.
Mac powers the external SSD, but does not start the external ssd. No image on HDMI.
No reason to search for image/backlight, if you cannot confirm USB activity.
I suppose the board has more corroded points...
iClub
Not from the image and not even the sound signal that it is connecting, can be the BIOS causing it ?
iClub
I rewrote BIOS, but it still has the same defect.
In the thermal camera it starts q3100 the component that presents greater heating.
You still have board areas affected by liquid, maybe even CPU is bad.
You should try first to heat BGA chips with quality flux and pass the board through ultrasonic cleaner at the end.
