820-00840 Anormal Q3100
Hello,
I have this A1708 board which does not go up to 20V
The USB-C controller area is clean
The u2800 area very damaged, I replaced U2800 and do some retrofitting, now very clean
Now I have these abnormal measurements:
Q3100
PPDCIN_G3H = 5V (GOOD)
UPC_XA_GATE1 = 7.25V (NOT GOOD)
UPC_XA_GATE2 = 10V (NOT GOOD)
Q3200
UPC_XB_GATE1 = 5V (GOOD)
UPC_XB_GATE2 = 0V (NOT GOOD)
LDO rails are good
Changing U3100 and U3200 seems like a solution to me, but I would like to know your opinion to avoid wasting time.
Thanks in advance
piernov
Moderator
Measuring voltages on Q3200 with USB-C connected to the corresponding port right?
Start by measuring voltage on the 4 LDOs of each CD3215 (USB-C connected to corresponding port).
Thank you for your fast reply :)
When I plug into USB-C A I get:
CD3215 (U3200):
PP3V3_UPC_XB_LDO = 3.3V (OK)
PP1V8_UPC_XB_LDOA = 1.8V (OK)
PP1V8_UPC_XB_LDOD = 1.8V (OK)
PP1V1_UPC_XB_LDO_BMC = 0V (I THINK OK?)
PP3V3_UPC_XA_LDO = 3.3V (OK)
PP1V8_UPC_XA_LDOA = 1.8V (OK)
PP1V8_UPC_XA_LDOD = 1.8V (OK)
PP1V1_UPC_XA_LDO_BMC = 0V (I THINK OK?)
Q3100:
PPDCIN_G3H = 5V (OK)
UPC_XA_GATE1 = 7.25V (NOT OK)
UPC_XA_GATE2 = 10V (NOT OK)
Q3200:
UPC_XB_GATE1 = 5V (OK)
UPC_XB_GATE2 = 0V (NOT OK)
When I plug into USB-C B I get:
CD3215 (U3200): the same voltage
Q3100:
PPDCIN_G3H = 5V
UPC_XA_GATE1 = 5V
UPC_XA_GATE2 = 0V
Q3200:
PPDCIN_G3H = 5V
UPC_XB_GATE1 = 7.5V
UPC_XB_GATE2 = 10V
I have 2 board with this identical problem.
It does not appear on schematic, nor boardview.
Very close to USB connector, opposite side of CD3215 chips; look for PI3USB32224 chip.
