820-00840 does not boot with battery connected.
Sr. Robot
It boots with the battery screw but not with the flex cable.
Fan spins for a few seconds and screen flashes backlight, then shuts down.
Tried several working batteries, no change. Also tried a different data cable.
J6950 is not shorted.
SCL/SDA lines are 0.369 diode mode to ground.
Resistance over C7020 is 2.5 ohms and C7023 2.8 ohms.
Q7065 is not shorted.
F7000 voltages:
Charger only: 13.0v
Battery only: 11.7v
Battery + charger: 12.55v
SMC Bypass not working
It was the palmrest, after replacing it turns on and works off the battery just fine. Even though i had tested it without connecting the trackpad flex cable, so i dont really understand how is it related to the battery.
