820-00840: not powering up P5VS4_EN missing
Originally PP20V was present but no PPBUS_G3H_CPU. Replaced Q7900 which restored PPBUS_G3H_CPU, but the board still isn't powering up. Missing PP5V_S4 due to P5VS4_EN being at 0v. PM_SLP_S5_L is also at 0v.
Other voltages i noticed was PM_EN_P3V3S4 which is reading 0.024, PMIC_EN_P3V3S5 is present @ 3.3v.
I've replaced U7800 with the same result.
Any suggestion as to why PM_SLP_S5_L is 0v or what else to check.
Yes to PP3V1_RTC @ 3.1v
and i'm only seeing one PCH's RTC signal, PPDCPRTC_PCH @ 1.66. Every other PCH RTC signals are omitted in the schematic and board.
RTC signals are not clearly delimited in this schematic, as in older platforms.
But you should be able to catch them, as they have the same names.
RTC_RESET_L, PCH_SRTCRST_L and PCH_INTRUDER_L.
PCH_INTVRMEN is not used anymore by this PCH generation.
Not much history just that it stopped working. No corrosion or sign of liquid spill or damage. There was a short on PPBUS_G3H_CPU which was resolved by replacing Q7900.
