820-00840 wont install OS
Kyle93
Arrived with no sighns of liquid damage. When trying to boot from recovery or internet recovery a error message occurs stating Mac OS could not be installed see picture.
Tried good known SSD with same results.
Any ideas what causes this and what to try next?
Kyle93
It does not load from external Mac OS now. The Apple logo will appear but the progress bar remains empty. Nothing else happens
Kyle93
I have the TL866A mini programmer and the Medusa 2. I just received the Medusa 2 and not sure on how to flash the bios from the computer to the EFI chip. Medusa 2 is plugged into the macbook through port A and port B is connected to the TL866A.
When I go to the miniprogrammer software from TL866A to select IC to 25 flash detect. No device is found.
What am I doing incorrectly? This would be the first time flashing with the Medusa 2
You cannot use Medusa with both ports connected at same time.
Connect TL866 to port B; should see an 8MB chip, like W25Q64 (Medusa ROM).
Flash the new file on Medusa ROM, and disconnect port B.
Next, connect Medusa to J6100 through port A.
Flash the new file on the Mac ROM.
Then clean ME, if needed.
If you changed the serial number in the new file (HxD on the PC), then also fix Fsys checksum in Mac ROM.
EVERY time you read Mac ROM into Medusa ROM, verify if get same reading one time more.
Do the same when you write from Medusa ROM to Mac ROM.
Kyle93
Thank you for the detailed explanation. The new bios was loaded successfully however the same OS installation error still pops up. See pictures
Install macOS on that SSD using other machine.
Then put back the SSD on this one; check what happens.
dukefawks suspects CPU, or RAM issue...
