820-00840
Board very clean - no liquid damage.
Both USB-C Ports showed signs of damage. Cleaned up damage as best as I could.
On one port I get 5v 0.00a on the other port I get 5v 160mA but if I spin the charging cable around I will get nothing on this port (AMP meter does not light up)
PPDCIN_G3H = 0.01v
I starting to think the ports are bad but could be wrong.
Thank you
These are the results for USB-C terminals. Do I still need to measure the LDO data lines or are these results below enough for me to need to replace the USB-C Ports? To me looks pretty conclusive that I'll need to change the ports considering the port pins were pretty messed up when I initially received the board.
Bad BoardGood Board
Side 1Side 2Side 1Side 2Side 1Side 2Side 1Side 2
1​
0L0L0L0L0L0L0L0L
2​
0L0L0L0L0L0L0L0L
3​
172172172172134138136135
4​
116574633633631619632619
5​
7567491.7520L0L0L0L0L
6​
00v1.7520v0L0L0L0L
7​
9690v1.7521.7520L0L0L0L
8​
172172172172134135135135
9​
313313313312331329331331
10​
313313312312330331331331
You should check LDOs too.
Some values on terminal ports are bad, but can be caused by failed CD3215 chips.
In such case, you should get bad LDOs readings too.
U3100 LDO readings not good so I replaced the CD3215 and now they are fine and I am now getting PP3V3_G3H. However, I was getting 0v on PPBUS_G3H. Reflowed ISL9239 and now am getting 2.5v on PPBUS.
I am waiting for a delivery of ISL9239's and will change once received. Below are the readings for U3100 before and after the replacement
U3100 Before replacement
PP3V3_UPC_XA_LDO0v
PP1V8_UPC_XA_LDOA504
PP1V8_UPC_XA_LDOD0.016
PP1V1_UPC_XA_LDO_BMC484
U3100 After replacement
PP3V3_UPC_XB_LDO465
PP1V8_UPC_XB_LDOA495
PP1V8_UPC_XB_LDOD459
PP1V1_UPC_XB_LDO_BMC478
U3200 Readings seemed fine
U3200
PP3V3_UPC_XB_LDO446
PP1V8_UPC_XB_LDOA502
PP1V8_UPC_XB_LDOD467
PP1V1_UPC_XB_LDO_BMC485
