820-00850 - 5v / 0,25a
Palhano
Board had a short on the CB308, the UB300 a little burned. I replaced both, but the problem remains.
PPBUS_G3H - 12.3v
3v3_G3H_RTC - 3.3v
I have no voltages on the AWAKE and SLPS2R lines of the U7800.
It is recognized in DFU mode, I tried to revive and restore, both give errors.
Palhano
Yes, all ports behave the same.
I have 1.1v on all CD3215's. This line only has voltage on the connected port, correct?
Palhano
Strange, I went to measure, now I have tension.
PP1V1_SLPS2R : 1.1 Volt
PP1V8_SLPS2R : 1.8 Volt
PP0V8_SLPS2R : 0.7 Volt
PP1V2_AWAKE : 1.1 Volt
PP3V3_AWAKE : 3.3 Volt
Yeah, it shouldn't enter to DFU without these voltages.
I just wanted to confirm actual state.
What error do you get in DFU?
Any SSD, or G3S voltage tries to appear?
Palhano
In DFU it stays a long time on "Installing system" and then the error:
Gave up waiting for device to transition from
DFU state to DFU state.
[com.apple.MobileDevice.MobileRestore -
OxFCA (4042)]
I have no voltage on SSD, PP1V8_SSD and PP0V9_SSD!
nothing on the G3S 3.3v and 1.8v line.
Be sure no short on any SSD, or G3S power rail.
I had a case when these voltages come on after several failed DFU attempts.
Palhano
I bought the S-UEM2 device and decided to go back to work on that abandoned mac.
It showed changes in some pins of the UB300 (31, 33, 40, 42), as it had already been changed, I tried to change it again.
