History: Machine sustained severe liquid damage from a pet peeing on the machine. After opening it up, numerous signs of corrosion were noticed. The board was put through an ultrasonic cleaner and then checked again with just the board on the bench.
No obvious shorts on the board
PPBUS_G3H - Present - 12.28V
PP3V3_G3H - Present - 3.32V
PP3V3_S5 - Not Present - 14.4k Ohms (Resistance measured without adapter plugged in)
T2 Chip appears to be heating up a little before shutting off in a loop.
Attached is thermal imaging and Power Draw graphed out
Data is important for this one
