820-00850-A not drawing 20v
Soji
The 4 cd3215coo are heating up, I replaced all of them. Still 5v
voltage readings
PP3V3_G3H_RTC_ISOL-3.391v
PP3V3_UPC_XB_LDO-3.354v
PP1V8_UPC_XB_LDOA-1.8v
I can't find PP3V3_G3H_RTC_ISOL in schematic.
If all AWAKE and SLPS2R voltages present, try DFU mode.
Machine tries to start with known good battery?
Soji
The macbook is working perfectly well with battery just that it’s not charging.
after changing the 4cd3215c00 all the ports are drawing 5v but one out of the 4ports is not drawing current.
The topic should be not charging. Sorry for the mistake.
Battery will not charge, until get 20V on USB-C ports.
Compare diode mode readings around all CD3215 chips.
Be sure to check all points in the same way (red probe at ground).
"one out of the 4ports is not drawing current"
Which port is that one (reffered to schematic)?
Soji
J3300 red probe on ground.
No resistance on
USBC_TA_USB_TOP_N
USBC_TB_USB_BOT_N
And the port without current is from this connector.
Soji
Sorry my bad. It’s JB500 ports are drawing 5v with current.
but on j3300 both ports are drawing 5v but one of them is not drawing current.
Compare diode mode readings between the lines of USB ports.
Remove the connectors from the shell and inspect the terminals.
