On J8500 pin 6 DP_INT_HPD diode value is 1.5 and i took another board which is 820-00239-a and it's 0.45 on the same pin same network and goes directly to cpu...
Yes red probe on ground as it should be for diode mode reading. I check all resistors also replaced R4830 cause on pin 1 which comes from pin 2 of q4830 it has 1.647 diode mode value and on pin 2 of R4830 it has 0.568. I also replaced q4830 but no change. All leads to a contact under the CPU which probably broke cause of overheating
