820-00850 - does not charge battery
Palhano
The device turns on normally with the battery charged, but the Mac does not recognize the charger in any port.
With the battery, I have 20v 0a. Without the battery, the Mac does not turn on, I have 5.13v 0.23a.
I have 12v on the PPBus. In the CD3215 tests I noticed that at times I have, in diode mode, 0.140 on the PP3v3_G3h lines. But with the charger, I have 3.3v.
The measurements of the u7000
P_IN - 5v
AUX_DET - 1v
SMC_RST_IN - 0
VDDA - 5v
VDDP - 5v
EN_MVR - 5v
SMC_RST* - NC
AUX_OK - NC
AMON - 0
BMON - 0
Any history available?
"in diode mode, 0.140 on the PP3v3_G3h"
Do you mean 3V3_G3H_RTC?
Inject 3.3V there and check with thermal camera if any CD3215 heats a bit more than other.
Palhano
No history. The board is very well preserved, without oxidation or liquid marks.
Sorry! Yes, it was the 3V3_G3H_RTC line. After a while without use, the board showed 0.380 when measured in diode mode, but when I put the charger in and took it out, it went to 0.120, 0.140!
I injected 3.3v, the power supply pulled 0.050a and nothing got hot.
Then is no problem there.
Always allow 10-15s before checking in diode mode, once power is removed.
Do you get all expected LDOs for all CD3215 chips?
Palhano
I've never done this procedure. I need to look for the socket for this chip. Does the ROM have any specific files for this model?
Palhano
It didn't work. It still doesn't charge the battery. I checked all the resistors near the CD3215, and I didn't find anything wrong.
Any other tips?
Palhano
The situation has worsened.
I no longer have 20V with the battery and the Mac no longer turns on with the battery.
With and without the battery, I have 5V and 0.23A on all ports
The LDOs are perfect. PPBus 12.2V. I tested the ports with the S-UEM2 and it did not show any problems.
