820-00850 No power / No H2O
No water damage.
DC IN = 5.20V 19.24ma except one port is 5.20v 18.92ma
PPDCIN_G3H = 5.2v
PPBUS_G3H = 0.00
PPVIN_G3H_P5VG3S = 0.00v
PPVIN_G3H_P3V3G3H = 0.00v
LDO DIODE MODE=
UB300
PIN 2 -PP1V8_UPC = 0.443
PIN 35 -PP1V1 = 0.449
PIN 53 -PP3V3= 0.484
PIN 75- PP1V8 =0.464
U3100
PIN 2 -PP1V8_UPC = 0.467
PIN 35 -PP1V1 = 0.484
PIN 53 -PP3V3= 0.480
PIN 75- PP1V8 =0.504
U3200
PIN 2 -PP1V8_UPC = 0.449
PIN 35 -PP1V1 = 0.478
PIN 53 -PP3V3= 0.482
PIN 75- PP1V8 =0.467
UB400
PIN 2 -PP1V8_UPC = 0.437
PIN 35 -PP1V1 = 0.453
PIN 53 -PP3V3= 0.483
PIN 75- PP1V8 =0.468
No 3V3_G3H, so cannot get 20V on USB-C power port.
Post first diode mode there and check CHGR_EN_MVR level.
On U7000, check AUX_DET and VDDA/P voltages.
JB500 DIODE MODE
PP20V_USBC_TA_VBUS =
PIN 60/59 = 0.124
PIN 58/57 = 0.124
TP_USBC_PP20V_TA = .0L
TP_USBC_PP20V_TB = .OL
J3300 DIODE MODE
PP20V_USBC_XB_VBUS =
PIN 60/59 = 0.125
PINS 58/59 = 0.125
TP_USBC_PP20V_XA = .0L
TP_USBC_PP20V_XB = .0L
U7000
CHGR_EN_MVR
DIODE = O.576
voltage = 1.29v
CHRGR_VDDP
= 5.07V
VDDA = 5.07V
Please read the posts, do not waste the time.
I do not remember to asked you about J3300, or JB500...
"check AUX_DET"
"Diode mode F7000
PIN 1 = 0.00
PN 2 = 0.00"
If these are real diode mode to ground values, you have short on PPBUS_G3H.
Please confirm if is the case...
What is the best way to find that short given that all of the line is shorted? I'm still having trouble with that. I know I could start pulling components off but that would be a lot of work. Is it by voltage drop at different points or...Diode mode? This is something I need to brush up on and understand. I would be in your debt if you could just lead me even in the right direction and I can research proper procedure.
What I've read or seen is that you can use Ohms mode and test components. As you get further away from the short there will be more resistance.
Or if I find components that are closer to 0.00 in diode on the shorted rail should I inject voltage on those components and see what heats up?
You can check for USB activity, with the board on the desk.
Or even external video, with proper HDMI adapter.
Do NOT do the error to inject again voltage in the same manner into PPBUS_G3H!!!
You had ton of luck this time; don't force your luck.
