820-00850 no turn on
geo8610
NOT AVALAIBLE HISTORY
DFU MODE IS NOT RECOGNIZED
PP3V3_G3H=3.3v
PP5V_G3S=5.1
PPBUS_G3H=12.35
PP3V3_G3H_RTC=3.3
PP1V8_SLPS2R=3.3V
PP1V2_S3=0V
PPVCCEDRAM_S0_REG_R=0V
All USB-C ports switch to 20V?
Test disconnecting battery (87W charger only).
You can try reflashing SoC ROM; should enter into DFU automatically.
geo8610
yes,all ports switch 20v
test disconnecting battery same problem
with which adapter reflashing this memory Rom U4770? I have programmer sofi sp8-a, I don't know if I work for this chip
geo8610
The programmer I have is 3.3v, can this board serve as a 1.8 adapter?
A4069 Level Shifter to 1.8 volt with Solder Spaces
geo8610
ok, the board A4069 works for the soc rom U4770, says uson 3X4 page product that works for me?
Why not, if has USON 3x4mm?
"Connect 3v3 side to Medusa and solder a 1v8 ROM onto this board."
Connect 3V3 side to your programmer, instead of Medusa.
geo8610
I already programmed and dfu enters but an error appears when I try to restore or revive in dfu mode it appears installing the system dfu error appears
AC2 shows DFU, or Recovery?
If appears in Recovery, force the target Mac of and try to put it in DFU again.
