820-00875-01 Spill no screen
U8400 pin 17 has no voltage. The cap connected to it C8442 is gone. What is sending BKLT_EN_R signal and what voltage should it be ? Is it Q9908 ?
That's not good.
I supposed you've got 0V there before.
Do you get image on internal screen?
USB activity at least, external video?
I've put it back together, everything works except the backlight - keyboard, trackpad, screen, system boots if I light external light to it I can log in etc.
Seems like U8400 is not being told to turn on the backlight and not drawing down the voltage on R8400 - Q8400 [3] ?
Maybe the enable signal should be debugged somehow ? I don't know how. From other posts I could see there should be 3,3V on U8400[17] - I have 0 there.
Traces look, fine, I have connection from U8400[11] to R8402[2]. R8402 is the one I had to solder on a broken pad, but I checked and it has connectivity both ways and it's not touching GND anywhere. Seems like 12V goes from F8400 > R8400 > R8401 > R8402 > U8400[11] but it's not switched to GND in U8400.
TP[1]PP5V_S0_BKLT_A - 5V
TP[1]EDP_BKLT_EB - 0V
No voltage on both sides of R8442?
Check if the first few seconds, when machine chimes.
Try known good compatible LCD assembly.
yes, both sides R8442 0V
"Check ib the first few seconds" - don't understand that.
Only LCD assembly is what I have from the original computer.
