820-00875 A1908 Not Powering up
CRC2018
So got an A1708 in today doesn't appear to turn on,
When the charger is connected it does go up to 20v and also appears to charge the battery - the trackpad clicks but nothing on the screen. No fan spin but the CPU does appear to be getting warm. Caps lock doesn't light up when pressed, PRAM reset doesn't work, SMC reset does work.
Found a small amount of corrosion on U3780 so have removed, cleaned and replaced but the behaviour hasn't changed. No other visible corrosion or liquid anywhere else on the board.
Board is drawing 20V and 2.8A when battery connected and 20V and 0.40a when battery disconnected.
CRC2018
L7210 - 0.930V
L7220 - 0.930V
L7370 - 1.044V
All three are stable
No voltage on L7410, L7420 or L7430
Should've said before that I did try external monitor and there is no output there either.
