820-00923-A, known good tp/kb ribbon, not working.
daxxone
Board had slight bend, replaced pretty much everything, but the board never seems to work with built in tp/kb. Bought a macbook pro to test and the parts I got are good on the test system. the tp feedback still works, not that it matters with this design, but 3.3v and 5v are also present. Afraid this is a bad solider joint somewhere on the I2C SCL/SDA lines but am open to looking at other things. What would you look at first to narrow down the source cause here? I don't know how to test these signal lines.
Any more information about how the problem appeared?
I suppose your problem is trackpad related.
KB can't work also, if TP is not working.
Check all TPAD_SPI resistors and traces.
