820-00923-A
Soji
This board displays fine but when it goes to sleep or close the lid there won't be backlight anymore...
I have tested with known good screen but problem still persist and no corroded area or component on the board..
Soji
No corrosion at J5250/60
Lid open HALL_SENSR_LEFT =3.4V
HALL_SENSR_RIGHT=0V
Lid closed HALL_SENSR_LEFT=3.4V
HALL_SENSR_RIGHT=0V
HALL_SENSOR_LEFT/RIGHT both signal must be high when lid id open and 0V with lid closed.
Working with the board alone on the desk, you can use small magnet to simulate lid action.
Does right sensor (J5260) get 3V?
Soji
Still the same with board alone on desk
HALL_SENSR_RIGHT=0V
After I approach magnet to j5260
Approaching the magnet can only drop the voltage; at least left Hall sensor (J5250).
Your right Hall sensor (J5260) is bad, unless it doesn't get 3V3_G3H; which you didn't confirm yet.
Soji
There is no 3volts on it ..
I found 0.362 diode mode to ground on one of the peel pads which i think the resistance is for 3V3_g3h
