tcampbell34
I actually have 2 of these 820-00923 boards that have the same issue. Both had the same initial damage, liquid damage on J4402 and pins 22 and 20 melted and damaged the board in that area and the touchbar cable. The rest of board looks completely clean. I checked and there is no short on either of those rails, and when I plug the board in, I get 20v 0.9 amps for a few seconds and then it drops to about 650ma and stays around there. I have 0.991v at L7210/20 and 0.767v on L7410/20/30. I do have USB activity (tested with USB flash drive and the light flashes steadily), but no caps lock reaction or chime. I get about 1v on PPVCCEDRAM_S0_REG_F, but have 0v on PPVCCEDRAM_S0_CPU. I assume there was an overvoltage on PP5V_S0_T139 that caused the touchbar connector to melt, but maybe that assumption is wrong. PPVCCEDRAM_S0_CPU comes from U7760, which is powered by PP5V_S0, but the enable signal PM_OPC_ZVM_L is 0v. That enable comes from U7790 from CPU_ZVM_L, which is also 0v. Not sure where to look on this now since that seems to come from CPU. Any idea what would cause this?
