820-00923 no power
Kyle93
Arrived with liquid damage and severe damage to J9600. Data is important.
Diode mode reading on pin 4 J9600 is 0L and donar board is 0.432. Repaired all other traces on J9600
Is data still saveable if U8600 is replaced from donar board?
Kyle93
There is no continuity between SSD_BOOT_L and SSD_BOOT_LB_L lines. Does this need to be fixed at J9600?
You must have continuity between all left/right pins of J9600.
If only one is bad, run wire between corresponding pads into board.
Internal SSD connects to PCH through J9600...
Kyle93
PP1V8_SUS is shorted. Removed everything but CPU but short remains.
CPU needs replacing now in order to retrieve data?
Kyle93
Which pins on J9600 need to function with continuity to retrieve data with tool? I already have the tool
Kyle93
No response on tool. All pins have continuity now but pin 4 SSD_BOOT_LB_L is 0.77 diode and on donar is 427. Is this bad U8600?
Kyle93
Trying to replace U8600 pad 315 PP1V8_SSD_HOT is missing however all other pads are present after cleanup. Will replacement U8600 still work for data recovery with this pad missing?
Kyle93
To save trouble of replacing U8600 would the data be readable or even boot into the OS if U9120/U9200/U9100 were moved and soldered to a working 820-00923 board since these have the T1 chip?
