820-00923 - touchbar maybe
hello
i have replace screen for this model. After machine start in recovery and i have message need updating but impossible
normally it's touch bar, i have replace with 3 touchbar and new original flex cable and same
i have test fpc connector and see line DFR_TOUCH_INT_L to gnd
on schematic i see R4485 but no stuff and line go to U3900
you think need replace U3900 or other idea?
Before in other machine i have see problem mainboard when screen have remove but on this not see this problem
Thanks for your help
Something could get damaged in the replacement process.
Check around all screw holes and connectors.
DFR_TOUCH_INT_L is shorted to ground even with touchbar disconnected?
Ooops, that points to bad T1.
If you are lucky enough, may be only bad J4402.
You can inject until 2V there, for test.
