820-00923 water damage 5v no ppbus
I was expecting some diode mode readings there; eventually replacing these caps.
If U7000 gets correct P_IN and AUX_DET, it MUST generate 5V on VDDA/P.
You can calculate it from the resistor divider which generates it.
Its value depends if USB-C port provides 5V, or 20V.
Any voltage at PPBUS_G3H now?
USB ports still stuck in 5V?
Connect battery and check 3V3_S5 reaction triggering SMC_ONOFF_L (at same time); use R5225/6 pads, instead of power button.
Can you get a known good battery for test?
Be aware, "new chinese" doesn't mean "known good"!
Remove F7000 and check C7050 voltage.
If nothing, post diode mode reading.
