820-00923 Zero Volts on one CD32. What's that mean?
down1nit
Every other port does 5v/reboot loop. One CD32 (u3200) just does not seem to make a circuit at all. Is it hard fucked or am I missing something. I tested fuse, looked for obvious shorts.
Also any tips on digging out underfill if I have to replace this?
down1nit
Yep the 3215 was dead. It boots now, but does not see the SSD. p2v7 is missing and p2v7nand_en is missing on pin 15 of u9400. That said, there's damage near Piccolo, is this the signal source?
down1nit
Ah. Thank you 2. First tech sent it thru the buzzy water. I'll put the terminator on it'll probably be fine.
Has anyone else spent over a thousand dollars on a buzzy water machine?
