820-00928-A spillage of liquid No power no charge
tipoti
PPBUS_G3H Isn't the u7000 considered defective because it has no voltage?
I injected voltage into the f7000 from the outside. There is no short circuit. no hot parts
U7000 requires correct communication with SMC, to generate correct PPBUS_G3H voltage.
Injecting voltage into a power rail where you don't have short, or incorrect resistance to ground, doesn't help at all.
Did you test the board with known good battery (holding some charge)?
tipoti
It has a 5 volt cycle
I noticed that the capacitor I just marked has a short circuit with ground. I can't see this field in boardview.2021-12-28 15_35_39-Ekran Alıntısı Aracı.jpg
I think that was already mentioned on the forum as being normal.
This is one of the reasons I said the people to read EACH forum thread and take notes when important information appears!
In case of 5V cycle, you should check for short, or low value on all secondary power rails.
However, I'm afraid you have a lost caused here, because of liquid damage...
tipoti
I did not understand what you said. The question is, the capacitor in the place I marked is short-circuited. But I can't see it in boardview. How do I find where it is connected?
I said we have another thread on the forum mentioning this.
So that is normal short reading for that cap!
No idea about its purpose, as is not present in schematic, nor boardview.
