820-00928 boot issue
Kyle93
This arrived with fast fan spin and unable to load the O.S. Data already backed up before the issue started.
Q3200 was shorted and getting excessively hot. Removed Q3200 but since it was welded to the board from the short replacing it is not possible.
Fans spin fast within couple minutes of power on. Previous shop ripped Q6000. Replaced and all traces are good however still fast fan. Resistors measure good.
When trying to load os recovery the apple logo and progress bar will disappear within a few minutes with the blinking question mark folder.
Drive is visible when holding option. Windows section will crash within a few minutes. Mac os installer goes to question mark folder after the progress bar finishes.
Customer wants only mac os now. Changed bios as well but no change. Is this looking like bad SSD?
Test starting in safe mode.
Also check if any error pops up in diagnostic mode.
Can you load preinstalled USB macOS?
Kyle93
Diagnostic mode says there may be a problem with the SMC
When trying to load from a preinstalled USB macos a critical software update is required but an error was encountered appears.
Seems to have a problem with internal SSD.
BTW, post a screenshot of diagnostic mode eror.
There is an error code and some related message.
