820-00928 PP1V1_UPC_XA_LDO_BMC 0V PPBUS 0V
No-Clean
Board had a little bit of corrosion 3 ports restart at 5V every few seconds except U3100 that one stays at 5V I replaced U3100 3 times and same thing, also only on that port PP1V1_UPC_XA_LDO_BMC is 0V, PPBUS is 0V, I also replaced U7000 but same thing.
You have a problem on that port with missing LDO_BMC.
Compare diode mode readings around U3100 with another port.
S-UEM2 can help you with some checkings there.
Diode mode on port is on par with working board, I also replaced from same board U2890 and U3500 same thing
