tcampbell34
Hello. I got another 820-00928 which looks very clean. No signs of liquid damage or corrosion, but it does not see the internal SSD. It is also slow to start it seems, and take 10 minutes or more to get to the flashing folder icon. When I plug in the charger and hold down the option key, it takes about 1-2 minutes before the backlight will come on, but no image. After another 1-2 minutes, the image will show up and I can select a drive to boot from. I was able to load the Catalina installer and open disk utility, but the internal SSD is not shown. Ran diagnostic mode and as expected, it gave me error VDH002 "There may be an issue with a storage device", but I also get PPF004 "There may be an issue with the fan". Both fans seem to be working correctly so maybe that points to something else? I have checked all voltages for SSD on page 84 of schematic and they are all fine. I have tried PRAM reset and SMC reset, with no change. Tried to boot in SMC bypass mode, no change. Tried a know good BIOS from the same model, no change. Is there anything else I can try?
