820-01041 5v
Sr. Robot
820-01041 with no signs of damage.
i get 5v on 3 ports and 20v on the XA port.
There are no shorts to ground on any of the LDO lines on the CD3215 chips.
When on the XA port:
PPBUS_G3H = 12.24v but still no boot.
Sr. Robot
I replaced UB090 just in case, but no change.
Note: i did test each 1v1 line with its corresponding port connected. All other LDO lines have correct voltage.
Sr. Robot
Sorry, i made a mistake, one of my probes was displaced and the multimeter was not reading correctly.
I do get 1v on the 1v1 ldo lines except on UB300 (the only port that has 20v).
Replaced UB300 but no change.
Diode mode on PP1V1_UPC_TA_LDO_BMC is still 0.450.
No history available.
Tested board with charger battery but no boot, ppbus is 11.3v
Sr. Robot
PP1V8_SLPS2R = 0v / Diode mode = 0.368
PP1V1_SLPS2R = 0v / Diode mode = 0.230
PP0V8_SLPS2R = 0v / Diode mode = 0.172
PPVDDCPU_AWAKE = 0v
PPVDDCPUSRAM_AWAKE = 0v
PP1V8_AWAKE = 0v
not recognized in DFU mode
Sr. Robot
PP1V1_SLPS2R = 0v
PP3V3_G3H_RTC_X =3.3v
PP1V8_SLPS2R = 0v
LDO_CORE = 0v
PP0V8_SLPS2R = 0v
PP3V0_G3H_RTC = 0v
PP1V2_AWAKE = 0v
PMU_LDO3_OUT = 0v
LDO_RTC = 0v
Sr. Robot
Diode mode U7800 LDOs:
PP1V1_SLPS2R = 0.233
PP3V3_G3H_RTC_X = 0.374
PP1V8_SLPS2R = 0.368
LDO_CORE = 0.325
PP0V8_SLPS2R = 0.170
PP3V0_G3H_RTC = 0.388
PP1V2_AWAKE = 0.461
PMU_LDO3_OUT = 0.545
LDO_RTC = 0.325
R7900 was fried, replaced it.
PP3V3_G3H_RTC_X is now pulsing to 3.1v instead of stable.
PP1V8_SLPS2R pulsing to 0.8v
LDO_CORE pulsing to 2.1v
PMU_LDO3_OUT pulsing to 2.1v
LDO_RTC pulsing to 2.8v
i dont get 20v anymore on PP20V_USBC_TB_VBUS but 5v.
