820-01041 battery drain fast
yair37
no water damage or other know damage...
i was replaced battery, but still drain very fast.
CPU getting very hot 100c, U7210 L2011/21/31 and all the area getting very hot..
was also tried OS from external drive to see if its not from the OS but the same
any idea?
yair37
I was put the board it good working body with original battery and it act the same.. fast fan and battery drain very fast!
dont have error at Diagnostic mode.
cant be bad CPU?
what else can i check?
Fans go fast from the beggining, or just when CPU (maybe GPU) gets hot?
Battery drain fast in both iGPU and dGPU modes?
Didn't speciy if you tested with another heatsink...
yair37
If no powerful graphics is required, board should work on iGPU mode.
Playing a video, may switch to dGPU.
Check if gfxcardstatus is supported on this machine.
yair37
Its the CPU temp goes high.. when i open Terminal and write the "yes" command its start to get hot and fans goes high
Then should be internal CPU issue.
Same happenes if you test with battery alone?
Depending of the combination charger/battery detected, macOS should adjust several clocks.
This may be reflected in the machine behavior.
Connect external monitor and test again.
This will enable dGPU, disabling iGPU.
Just to see if CPU still gets hot; expecting a problem on its iGPU area.
yair37
I was connected to external screen, it’s the same, it’s getting hot just when the CPU start to work even little bit hard..
Then should be CPU core problem, not iGPU related.
Just in case, try DFU restore.
Don't forget to save data first.
