820-01041 stuck at 5V 0.38A
Kappy
No liquid damage found on the board. 3 ports were going at 5v 0.42A replaced UB300 as it had a short to ground on PP3V3_UPC_TA_LDO. That is now cleared and I get 3.3v on that line.
The board is missing PP3V3_S5 and PP5V_S5_LDO (not sure if they are supposed to be present at 5v)
My main concern is PP1v8_SLPS2R as this is showing in diode mode 0.008 ( 8.3ohms) should be 0.040 but when i apply usb power i get 1.8v on PP1v8_SLPS2R
I hooked up my USB-C analyser and this gave me a fault to pin 33 on J3300 so i replaced U3000 and that's now cleared. No other faults reported with the USB-C analyser.
I've tried DFU mode - failed
So i'm not sure if PP1v8_SLPS2R is correct and why the reading is low.
All 4 ports are giving the same reading and there is no boot loop.
Any help is appreciated.
0.008 is too low for 1V8_SLPS2R power rail.
There is a problem for sure.
The correct voltage can be generated even with lower resistance than normal to ground.
But this denotes problems with something connected there.
Kappy
Where would you suggest the problem is.. U3000 or maybe U7000? This power line is used all over the board.
Is it going to me a matter of removing each component until it's found?
Inject 2V and use IR camera.
May help you to detect small temperature differences.
Remove CPU heatsink first.
You may need to wait several minutes...
No problem to inject 10% more.
You can try 1.5-1.8V, but will not be easy to detect temperature difference.
Even 2V may not help...
Kappy
Prefect... Found the problem to be the CD3215 (U3200). Replaced and now working again.
Thank you for your help.
