820-01521 2019 Air not starting up
sekidata
This 2019 Air board is at 20V USB-C (0.02A) with PPBUS at 12.6V. No signs of liquid damage.
It enters DFU mode but any T2 firmware restore attempt ends with error 9, even with connected good battery and Apple charger.
No shorts on the big coils or the small coils around U7800. I am missing the S5 power rails as well as PP1V2_S3. Also missing are some of the power-good input signals into U7800: PVCCIO_PGOOD, CPUVR_PGOOD, and PVDDQ_PGOOD.
Anything else to check before I blame this on a faulty T2 chip?
sekidata
Do you have any hints for how to get a reflashing setup started? What's the best way to be able to handle different sizes of chips?
sekidata
When I force the machine off with the power button, it disappears in Apple Configurator for a second, then immediately reappears with the DFU icons on its own.
sekidata
I confirmed on another machine that the persistent DFU mode is the default state after reflashing the SoC ROM. The board enters DFU mode as soon as power is applied, ready for a DFU Restore.
On this particular board, DFU Restore fails (I think) because I'm missing PP5V_G3S and PP2V7_NAND.
I got several times SSD voltages after DFU revive/restore.
So DFU should fix it; unless is caused by another problem, not T2 corruption.
sekidata
When I revert to this board's original SoC ROM dump, I still get the above error ("added from invalid state Restoring") during Restore attempts.
