820-00850-A - Tries to turn on and restarts
mushr00m
What I do have is this things.
Does not seems to be a 1.8V adapter, right?
mushr00m
OK. Gonna buy all of those things and follow your procedure in 2 weeks it arrive here and I will let you know!
Thank you very much!
mushr00m
Finally arrived.
Can you give me instructions on how to assemble it?
The CH341 and 1.8V adapter I guess Its right image below!
Solder the chip on the black board and insert it into 1.8V adapter.
Then insert the adapter into CH341 programmer.
Be sure to connect all properly.
Many videos and pictures should be available on Internet.
mushr00m
I am afraid to connect the pins on the wrong position. Can you give me more guidance
mushr00m
I understood the basic logic
I am only not sure if I am inserting on the wrong pins
and the black board I do need to solder those pins that were soldered on the older board which I used on Macbook A1278 right?
Also the black board does not have pin numbers... not sure where to connect on the 1.8V adapter!
mushr00m
I did NOT find a single video using the BLACK programmer
I even asked the seller to send me a video with instructions. If you have a link of at least one video/picture with instructions that would be great!
If I tell you pin 4 of the chip is ground, is that sufficient to find its orientation?
In fact, each pads group on the black board has pin 1 marked with white circle.
CH341 has also marked on the board position chip for 25xx series.
You've placed 1.8V adapter correctly there.
On the holes where you need to solder pins on black board, don't you think one hole has a different marking?
What pin do you think is that?
mushr00m
To be honest I got confused because on the blackboard it also mentions 1.8V which is pin 8 on U4770 (PP1V8_AWAKE also image attached) so I soldered like that. Please confirm if I soldered on the right position. Always prefer to be safe than sorry asking you here
THANKS!!!
I think its PIN 4 and its GROUND but if thats TRUE the blackboard DOES NOT connect to the adapter because of the lever (image attached)
However I put the blackboard connected with the single position its could be connected using PINS.. Please also confirm
As usual prefer to be safe than sorry asking you!
The black dot on the chip marks pin 1.
How can you soldered it in reverse way???
I said the circle marks pad 1 on the black board.
Apart of the (BIG) circle, pad 1 is also marked with small white dot.
mushr00m
OK I just soldered the right way. with PIN 1 of the IC soldered on the WHITE CIRCLE
However can you explain me why PIN 4 which is GND now is connected to 1.8V WHITE name in the black board? For me it DOES NOT MAKE ANY SENSE!
Also I send you pictures of the black boards connected to the 1.8V apdater is it connected in the right way? You did not answer me this question
Pay more atention and put some logic.
All the group pads are connected together for the same pin.
Simple measurments can clarify you, instead of making wrong assumption.
"1.8V" is a mark for T2 ROM group pads.
Is just an warning; you can fry T2 ROM if don't use 1.8V adapter!
"black boards connected to the 1.8V apdater is it connected in the right way?"
YES.
As simple as checking if ground pin (4) of black board corresponds to 1.8V adapter ground...
mushr00m
OK
Soldered PIN 1 to that CIRCLE (image attached) on the black board and assembled everything as I mentioned here and you confirm as right
However it does NOT detect EEPROM (image attached)
The CH341 is properly installed with driver and its working on windows. (image attached)
Whats wrong?
mushr00m
I think its the adapter I just noticed the IC on the adapter itself is getting really hot.
The position that you told me is the right one, ok?
How about that jumper on the CH341 its default when I bought it... Is it right?
